Salta al contenuto principale
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
Why USB ports are not working
the USB is not working I tried all the Dell diagnostic and it is failed.
I tried to rest and still not working.
BIOS is good.
I need to get it repaired but dont know which chip is responsible as both usb ports are not working
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
1 Risposta
Risposta Più Utile
Most common case is the burn fuses of the USB port.
A) Check the fuses – if available
B) You can check the power rails and it should be 5V – if you get >4.0V check the main PMU (Power management unit)
C) 3rd Gen Intel core CPU works with PCH (Platform Controller Hub), the PCH is the responsible chip for USB functioning
Punteggio 1
Aggiungi la tua risposta
lulujaimearredondo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,545
