Salta al contenuto principale
The AmazonBasics BTV1 is a portable Bluetooth speaker that also includes a microphone for conference calls.
How do I fix the crackling noise in my speaker?
Whenever I use my speaker I hear crackling sound whether I am connecting it through the AUX cable or through Bluetooth. How can I fix this?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you are connecting via aux cable, the most likely solution is to make sure your cables are fully connected. Check that your cord is firmly connected both to the speakers and the device you are using for playback.
If using a Bluetooth connection, make sure you within the speaker’s range of 30 feet (9.1m).
For more information on your speaker, check out the AmazonBasics_BTV1_Troubleshooting page.
Punteggio 0
1 Commento:
My Kindle is only 5 - 10 feet from the Braven speaker and it still crackles. Any other solution?
da
Aggiungi la tua risposta
firas bashir sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 5,689
