Weird Graphic Issue (Vertical Stripes/Banding) on Certain Elements
Hey guys! I've been searching everywhere for an answer and no luck so far. I'm getting strange Vertical Lines that show up only on certain elements on my SNES. For example, part of the bg hills in super mario world. You can see examples and the internals at the line below:
https://goo.gl/photos/a1RFPZ15weqMdbVZ7
Different games and cables still have the issues. Pulled the whole console apart and everything looks normal and clear. There does not appear to be any traces broken. 62 pin cartridge connector is clean with no bent pins. The brown discoloration around certain areas I cleaned up with 91% isopropyl alcohol, thought maybe it was cause by a leaky cap but it could be flux?
Any help would be greatly appreciated! Thanks!
Questa è una buona domanda?
6 Commenti
I have never seen this issue before. Are you using av cables or an rf module?
da Kris
Hey Kris, I've tried two different multi out av cables and the RF switch. All are authentic SNES. Thanks for your comment!
da Zach Bova
I've seen horizontal black lines before. (debug feature.)
but i have never seen this before...
da Jordan Fryman
I've just gotten the same issue! Please let me know what is wrong and how I can fix it. https://hosting.photobucket.com/images/y...
da imfuraisoth
Hey Imfuraisoth! Unfortunately I've not been able to dig into this issue any further. I hope someone else can recommend a fix for you!
da Zach Bova
Mostra 1 altro commento
