Salta al contenuto principale
Il Nike+ SportBand potrebbe diventare il tuo nuovo compagno di corsa preferito. Monitora tempo, distanza, ritmo e calorie bruciate su un display facile da leggere, inoltre si collega a Nikeplus.com dove puoi partecipare a sfide, mappare i tuoi percorsi e connetterti con gli amici, il tutto senza un iPod ®.
Device Won't Power On
My device LCD screen does not seem to display anything. I don't know if the screen is broke or if the device is broke.
Questa è una buona domanda?
Punteggio 3
1 Commento
i have a problem too to my nikeplus sportband its charging and it was detected on nike plus connect but wont show time nor functioning it just showing charging and full charge when charging
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
There could be a few things wrong with your device. First, we need to determine if the device has been charged or not. Plug the watch in to the charger and let it charge over night. If the device still doesn't turn on in the morning, the screen could be damaged. Refer to the Troubleshooting page for further help.
Punteggio 2
The screen works when plugged in it displays the Nike symbol
Punteggio 1
3 Commenti:
It just won't power on with the button looks like the button is damaged somehow
da
I have the same issue, the on button is damaged. It charge but does not turn on and the button cover looks loose.
da
I'm also having the same issue
da
Has anyone found an answer????
Punteggio 0
Aggiungi la tua risposta
Jesus Sarmiento sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 25
Tutti i Tempi: 5,749
