Salta al contenuto principale
The Black and Decker Air Station is a 160 psi air compressor that is designed to inflate a range of household items.
2 Domande Visualizza tutte
Air station quit working
I a ired up one tire then hooked my air station to another tire but the air station would not come on.I checked all I could check but it still would not come on.What can I do?Did the ac dc switch suddenly go bad?
Questa è una buona domanda?
Punteggio 1
1 Commento:
My air station will not blow up my tires. It blows air when not attached to the tire. HELP
da
Aggiungi un commento
1 Risposta
I just got me one of these at goodwill for $40 and I wish I had my money back! Your Air Station stopped working because the fuse blew just like mine did only the second time I used it. And guess what? I had to take it apart to get to the small fuse inside and this is a pain in the ass because you have to cut out the old fuse and solder in a new one.
Punteggio 0
1 Commento:
Hi,
There's always a reason why a fuse blows, so don't be ssurprised if it happens again very soon.
Fuses blow because excess current is flowing through them due to a problem in the circuit that they're there to protect e.g. short circuit turns in the motor winding or a component that has changed value for whatever reason.
What is the model number of the device?
da
Aggiungi la tua risposta
george m denison sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 49
Tutti i Tempi: 1,145
