Salta al contenuto principale
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
20 Domande Visualizza tutte
Why does my tablet keep shutting itself off?
My Nexus 7 has been having a problem the past couple of days where after I turn it on, it will run for a few minutes, and then it will freeze and the screen will go black, showing up with the google reboot screen a few seconds later. If I leave it completely alone, it will stay on for about 6 minutes before it shuts down completely, and if I try to actually do anything on it it turns off in way, way less time. I haven't been able to pin point it to a certain app of process, though some things will shut it down faster than others. It is making it impossible to use my tablet and I don't know what could be causing it.
Questa è una buona domanda?
Punteggio 11
12 Commenti
Ok I tried all the fixes short of having it professionaly repaired. I deleted all apps, finally it ahut down as soon as I turned it on. After trying many times i was able to turn it off manually. I then charged it while off .at first it didnt seem ti help but after a few time the shut downs became less frequent and now its running fine. I continue to close everything and shut it down before charging it to 100%.
da
Find a table with one leg about 1/2 inch shorter than the others. Place device under short leg. Leave it there and forget about it.
da
That might honestly be a better use for it at this point.
da
Oh that's funny. I have had computers and a few other things that were impossible to fix and I have used them as table legs, saw horses - - - Etc
da
My table keeps cutting off even when it's fully charge what can the problem be
da
Mostra altri 7 commenti
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hi,
Have you checked, if there is enough time to do so, what the state of charge of the battery is? Have you tried charging it to fully charged-100% . (do this with the tablet switched off so that it won't take so long to do) and then seeing how it performs.
If you have done the above and you still have problems, try connecting the charger (switched on) to your tablet and see if the tablet remains on when you use it. If it does then your battery is probably failing and it needs to be replaced.
Even rechargeable batteries have a life span.
Update (03/16/2016)
Hi,
Try the following and see if this resolves the problem. This is not a master reset so your information will not be deleted.
1. If your device is on, turn it off.
2. Press & hold the Volume down button. While holding Volume down, press & hold the Power button until the device turns on. You'll see the word "Start" with an arrow around it .
3. Press the Volume down button until you highlight "Recovery mode."
4. Press the Power button to start recovery mode. You'll see an image of an Android robot with a red exclamation mark.
5. Press & hold the Power button. While holding Power, press the Volume up button once. Then release Power.
6. Press the Volume down button until you highlight "Wipe cache partition," and then press the Power button to select it.
7. Press the Volume down button until you highlight “Yes,” and then press the Power button to select it.
8. Wait until the cache is wiped. You’ll see the words, “Cache wipe complete.”
9. Press the Power button to restart your device.
Punteggio 9
8 Commenti:
I have tried with the tablet plugged in and with the battery charge at 100, neither seemed to make any difference to the performance of the tablet, it was still having severe problems.
da
*Update 3/16/2016* Unfortunately the cache wipe did nothing to help the problem.
da
Hi, Try a hard reset. It will erase all your downloaded apps and user data and restore it to a factory default condition. Perform a backup first, if you can. Here is a link that shows you how. https://support.google.com/nexus/answer/...
da
It's probably a bad sims card. Take it out and try your tablet. It should do the trick.
da
On first look this may seem ridiculous, but it makes all sense to me. Mine is a Samsung Tab and it has the same problem, and the issue started a week ago when I got to South Africa and purchased a new SIM card for a local network. I had already tried everything mentioned above but the issue still remains.
Now I'll get a new SIM card from another network and then I'll post the results.
da
Mostra altri 3 commenti
Could it be the battery terminals on your phone? Once when my second hand phone went off, I found that one of the battery terminals on the phone was much shorter than the rest. Maybe it’s just not making good contact.
Punteggio 0
1 Commento:
Turns off every few seconds
da
It might be over heating
Update (07/23/2020)
I have the same problem with an entity tablet so the mane problem coyld be over heating maybe a certain app or game app
Update (07/23/2020)
Ahh now I know why the tablet shuts off
The batterys cells a drained you will need to to get a new battery if you can get a replacement
Punteggio 0
Aggiungi la tua risposta
Jenna Pierce sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 18
Tutti i Tempi: 74,566
