Hi Marty.
How to fix a split Fusion Drive
This is a support document from Apple USA.
There is a problem with your Mac, so it's worth a try.
The backup will be in the external SSD.
Another way is to kill a small built-in SSD.
Boot from the recovery area and format it with Disk Utility. Leave as it is.
Or start up in target disk mode and connect to Windows 10 machine.
Hit the Disk Part with the power shell with administrator privileges.
List Disk
Find the small SSD number of your Mac.
Select Disk * * is the target number.
Check well and type crean.
Although SSD exists physically, it does not exist ethically.
The disturbing person disappeared.
Good Luck
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
