There will be a few environmental variables here:
- Each screw is unique in size, differentiating by 0.2mm each. If the order is mixed up, a long screw could have penetrated the board.
- The flex cables are very fragile, and may have been damaged during the process.
- Pride aside, it's safer to replace the entire assembly rather than just one part, such as the screen but not the digitzer or fingerprint IO cable. Or, at least have the items on standby.
- Miniaturization of Electronics has placed much greater need of ESD protection, ESPECIALLY on iDevices. I wear Nitrile gloves, i have an ESD wrist strap, I work on an ESD mat, both items connect to a small junction box that grounds at the wall outlet center-screw. Nothing mysteriously breaks, ever - You should do these too. :)
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
Was the old screen functioning fine?
da Ben
