Salta al contenuto principale
The NeuTab N7 Pro tablet has a front and rear facing camera, 7-inch display, and is powered by Android KitKat.
23 Domande Visualizza tutte
I cannot download any media/applications on my NeuTab N7 Pro?
Every time I try to download an application on my NeuTab N7 Pro it starts downloading, but immediately stops. It says "not enough space". How do I fix this problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hey Robsander,
Your device is out of memory, so you need to clear up some space.
First, go to your settings menu, then select "Storage". From here you can see how much space is available on your device, and what's taking up the most space. You're probably going to need to go through your apps and delete extra apps you don't use. You can do this by selecting "apps" from the storage menu, then by selecting an individual app from there.
Be aware, many apps that came with the device can't be uninstalled, as they're needed for the android system.
If you need help with anything else, check out the troubleshooting page.
Punteggio 1
Aggiungi la tua risposta
Robsander Carrasquero sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 290
