Salta al contenuto principale
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Domande Visualizza tutte
Soldering Pad on A1395 Logic Board
Lost a couple solder pads while repairing PFC connector. I can see the copper trace where one of them goes, the other one doesn't look like it goes anywhere. Do all of the connectors have a connection? I think I could use a small piece of wire to repair the one, but not sure how to find out if the other one is actually used, and if so, where it goes. I attached a couple pictures. Thank's in advance.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The second photo is VERY blurry.
The first not so much.
I have a iPad 2 at home so i'll photograph that also for you.
I'll try locate the schematic diagram for you once i'm home from work (8 hours away).
Punteggio 1
Awesome, thank you, that would be such a help.
Punteggio 0
Aggiungi la tua risposta
jerryroncalli sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 120
