Salta al contenuto principale
Also known as the Moto G3—an Android smartphone released by Motorola in July 2015. It serves as an economical alternative to Motorola's flagship phones. Model XT1540 in the US, with dual-sim and "Turbo Edition" variants sold in other regions.
89 Domande Visualizza tutte
Why do I have such poor battery life?
Lately my Moto G's battery life has been horrible. It wasn't like this when I first bought it; now, a full charge won't even last a single work day. My phone switches to battery saver mode (which is practically unusable) just 6 hours after a full charge. I don't even use that many apps so I don't think there's a lot of stuff going on in the background. I don't understand why my phone loses charge so fast, even when I'm not using it. I've even tried turning off automatic syncing for all my accounts as well as automatic updates, but it doesn't make much of a difference. What could be causing so much battery drain?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hey Ahnaf,
If you want to double check that background apps are not draining your battery too quickly, you can go under settings and look under the "battery" tab. You will then be able to see what apps use the most charge.
Also, make sure to put your phone in sleep mode when you are not using it so that the screen is not using too much charge. In settings, under the "display" tab, you can set the phone to automatically go into sleep mode if it has not been used for a certain length of time.
Both of these solutions are in the troubleshooting guide.
If neither of these help, you may have to consider replacing the battery. Hopefully, someone will post a guide on how to replace a Moto G 3rd Generation battery sometime soon.
Punteggio 1
4 Commenti:
I'm gonna try to go through the list of apps in my battery tab before I replace the battery. Thank you!
da
I set to automatically go to power saver and optimize setting for apps. Lets see. Not sure about sleep mode.
da
Okay. When was your phone installed on the latest upgrade. I would suggest, if, possible, to revert to the previous An
droid.OS.
da
I always switch off the Data usage at bedtime. Go to settings, Data usage, tap Mobile data, tap Ok. Then I also switch off the mobile . When Power off appears on the screen tap it, then the phone is not just sleeping, it is switched off. During the day I'm constantly checking to see if I've got any apps still "open" after use. Even though not in use they could be operating, upgrading or communicating with the host, draining power and using up memory. Hope this helps.
da
Risposta Più Utile
Hi Ahnaf
Maybe your battery is faulty. Can you get new battery and replace the old one?
Hope this help
Punteggio 1
5 Commenti:
I really don't want to do that except as a last resort, I was hoping there might be other software-related things I could try first.
da
Wait maybe someone will have some software related answer, but for me it is a hardware problem and that I would do if phone come to me with this issue.
Good luck
da
I see. Thank you!
da
I also have the same problem my battery drains that much after all i t can't last for a day
da
I have the Moto G6. My first one's battery gave out after about 18 months. The replacement is dead after about 9 months. The case is sealed - YOU CANNOT REPLACE THE BATTERY.
da
Hi Ahnaf, I am facing the same problem, have u got the solution????
Punteggio 0
1 Commento:
I am also having the same issue
da
Aggiungi la tua risposta
Ahnaf Siddiqui sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 27
Tutti i Tempi: 15,209
