The lid of my trusty Krups coffee grinder is stuck
The lid of my Krups grinder is stuck. I can't toggle the activation switch enough to release the lid. I look forward to a solution.
Questa è una buona domanda?
I banged on the sides with a rolling pin and then could loosen the lid finally.
I put a plastic bag over the unit and then ran it under hot water (like a mayonnaise jar when the lid won't open). It worked. You have to tug a bit but you can feel it loosening. Be prepared for a mess to catch the grinds.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,216
Tried tooth pick, tried prying open with flat side of a butter knike, plugged it back in and tried pressing down to grind. It didn’t unplugged it and tried rolling pin knock on side if lid. It worked
da Tiger
