Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Removing the Heat shields from the board
I am currently removing the heat shields from an iphone 6s to perform liquid damage cleanup. I am having trouble removing the larger heat shield that is right next to the battery connector. I have already mixed low melting solder with the solder that is holding the shield down, but I am still not able to get it to break free.
Any tips or help on how to remove this shield without causing damage to the board would be appreciated.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Use a hot air gun.
Normally i use a hot air gun. 250 degrees C
hold the hot air gun vertically above the board. point it on the shield and do like a circular motion on top of it. after you do that for a bit use a tweezer and try to take the shield off every few secs. hope this helps
Punteggio 1
Aggiungi la tua risposta
Elliot sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 232
