Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
Screen popped after replacement .
I replace the screen on a 5C and the screen pops off on the left side , and a less in right side . Sound like isn't in place correctly , but it is .
Never had this happen with any other model. Anyone know what's going on here and if there's a fix
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta più utile
Its very typical with poor screen quality. You will likely find that the glass is actually "popping out" of the plastic frame. You could try to glue it with B-7000 or similar adhesive, but it may happen again. Higher quality screens have hot pressed frames, so the frame is very securely attached to the glass and this doesn't happen.
The only other possible cause which comes to mind, which would be if the glass is definitely not coming out of the frame, would be a swollen battery
Punteggio 2
3 Commenti:
Sorry Ben we post at the same time :)
da
haha don't apologise :) you said the same as me anyway :)
da
The battery is ok .
I believe is the screen quality at this point .
Ty
da
Hi
I have this problem before where the glass separate from the frame. This is case of not good quality of the LCD/Digitizer. If that's the case you will need to replace the LCD again.
Hope this help
Punteggio 2
Aggiungi la tua risposta
lorfuma sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 6
Tutti i Tempi: 204
