Salta al contenuto principale
Why has my display gone dark?
I have a Bose Wave Radio that is about 15 years old. It is just the radio w/o the CD player. My screen has gone dark. I don't know if the screen itself is bad or just the back lighting.
Questa è una buona domanda?
Punteggio 15
6 Commenti
Hi, What is the model number of your radio?
da
Thanks jayeff, it is an AWR1-1W (no cd player)
da
Where can I just purchase a new display to solder in?
da
Would anyone know the part number for the display module in a Bose AWR1-1W?
da
my model no is AWRC3P the display is very dim almost non existant
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Risposta Più Utile
I know this question is several years old, but I had the same problem for many years and recently found this online —IT WORKED!! My display is now visible at all times. Hope this fix works for others.
Screen is Too Dim ¶
You cannot read the display because it is too dim.
The Display is Not Brightened All the Way
You can brighten the display by holding down the CLOCK SET button and pressing the ‘volume up’ button. Otherwise, the display depends on how much light is in the room, so it automatically adjusts depending on the brightness in the surrounding area.
Punteggio 6
12 Commenti:
Screen is Too Dim ¶
=== The Display is Not Brightened All the Way ===
da
YA-FRIGGING-HOO! It worked! On A Bose with a CD player, push the CD Mode and hold Volume to increase or decrease the light. Thank you very much for posting this.
da
Thanks very much. I would never have been able to solve the light issue on my wave radio without your help.
da
YA-Frigging-HOO- Thank you thank you I have the radio/CD model and your instructions worked perfectly...
da
I turned my old BOSE radio brightness uo as bright as it will go but it is still too dim?
da
Mostra altri 7 commenti
Hi John,
This link shows the refurbishment of a Bose AWR1-1W. It describes the replacement of the electrolytic capacitors in the radio. Of special interest to you may be the ones mentioned which are connected with the display board.
http://www.antiqueradios.com/forums/view...
This next link I'm not so sure about. It is the circuit diagrams for a Bose Wave Radio 1996. Whether it is relevant to your model I don't know but perhaps it may be close and therefore give you some idea where to look, especially around the display area. Usually manufacturer's tend to keep the circuit reasonably the same for a model over a number of years. To download the file scroll down and click on where it says Download >> To download the file, please, click here! << Download
http://www.eserviceinfo.com/downloadsm/4...
This image is taken from the circuit diagram found in the link above. It may assist you in finding your problem. As explained, I do not know if it is the correct circuit
Don't know if it is helpful or not but you never know.
Punteggio 5
Aggiungi la tua risposta
john sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 104
Tutti i Tempi: 33,951
