Salta al contenuto principale
How to teardown to get inside the phone because of Water damage
Hi eveyone! I accidentally left my phone in my pocket and it went through the wash and I love my flip phone it has stood up to many hazards but the washer. The phone turns on when plugged in but it freaks out with the screen flashing and same with the buttons so I could use some help here. The screen has no water in it but I got a good feeling most of the damage is on the circuit board. Here is a picture of what my phone looks like. Just put that link in your search bar. I will appreciate any help I can get thanks.
[http://|LG Revere 3 VN170 Basic phone | LG USA]
Questa è una buona domanda?
Punteggio 0
1 Commento
Question just in side of the slot for the battery there is a small square silver covering what is underneath the covering in mine under the covering was a small square of copper on top of a larger silver rectangular piece of silver. Will the flip not work if that very small cooper piece is displaced?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
As you know, water and powered electronics don't mix, (unpowered is not that good either- powered is worse though). What you will have to do is disassemble your phone and look for any corrosion (usually coloured green or white and possibly furry) on the components and on the pcb.
You can try and gently brush away all the corrosion with a very soft toothbrush or a QTip dipped in isopropyl alcohol (90%+). Ensure that it is all gone. It may look like it if it is still moist from the alcohol but it may reappear once it dries so be aware of that.
Be sure not to brush/rub too vigorously as you don't want to lift the components off the board. Once you are sure that all the corrosion has been removed, - check both sides of the pcb and remove all the plug connectors from their respective sockets to ensure that there is none in there either, allow the phone to completely dry before reassembly.
Reinstall the battery (which should also be cleaned - be careful not to bridge the terminals) and hope for the best.
For future reference, if a phone gets wet, immersed in liquid etc, if possible, remove the battery as quick as you can. Removing the power can prevent a lot of problems occurring because water being a conductor can create undesirable electrical circuits which can and do damage components.
Unfortunately I cannot find a video which shows how to dis-assemble your phone so as to assist you further.
Punteggio 3
1 Commento:
Thanks for the tip on how to clean off the corrosion at least. So once I can find a video or some type of instructions on how to take my phone apart I can clean it up
da
Aggiungi la tua risposta
Joel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 835
