Salta al contenuto principale
Questa fotocamera istantanea di Fujifilm vanta ora un corpo più sottile e leggero rispetto alle versioni precedenti. La Mini 8 aiuta il fotografo segnalando l'apertura consigliata. Dispone inoltre di una modalità flash High-Key che aiuta a ottenere ritratti morbidi per un look straordinario.
Camera won't switch to different lighting settings
I brought my instax mini eight out for the first time to take a couple pictures on a hike, and when I went to adjust the lighting from indoor to cloudy, it didn't change. The orange light switched between all of the settings without me turning the dial, and eventually became stuck on the indoor setting. Can the camera be fixed?
Questa è una buona domanda?
Punteggio 7
5 Commenti
umm what if the lighting setting/the adjustment for the lights does not flash
da
My film wont came out and the censor light wont turn down even when i shut the camera down, how can i fixed it ? :(
da
my light doesnt change to any of the icons it just stays on "home" icon, I JUST GOT IT OUT OF THE BOX
da
My problem is that, all of the icons are all lighted? How can I fix this? Please I badly need help. Thank you
da
I had the same problem! It may be just a mechanical problem but if you look closely at the lense, you will see that it still opens and closes with each dial turned. The orange light is just showing what its on but with that broken, the whole thing still works. The lense with the biggest opening brings the most sunlight and the smallest opening is the darkest setting. Hope this helped!
da
Aggiungi un commento
8 Risposte
Soluzione prescelta
I don't think the camera is broken to begin with.
The orange light next to the exposure dial suggests the correct setting of the dial, it isn't supposed to change when you turn the dial. You just have to turn the dial so it matches the light.
The correct procedure is to point the camera in the direction of the subject, then turn the dial to match the light. Also, on the front of the camera next to the flash window there are two small round holes, be careful not to cover these with your fingers when you hold the camera: these are the light sensors, and they cannot work correctly when they're covered.
Punteggio 18
6 Commenti:
Its causing my photo quality to be bad or faded because its so sunny where I am at.
da
Thx so much It really helps me bc I thought mine was broken this lets me know that some people are also having this problem that can be solved
da
What if the light on the dial won't turn on
da
thank you so much, It never did that before so I thought it was broken.
da
I tried it in a really dark place and then outside when it was sunny, and the light dial still the same. This causes my photos to go dark, is annoying.
da
Mostra 1 altri commenti
thank u!!! this really helped
Punteggio 2
thank you so much!!!!!!!!!! I thought my camera wass broken bc it wouldn't switch light positions, but now i know it is fine.
Punteggio 1
1 Commento:
but i had this since last christmas, it was like thaat as soon as i opened it, and even in the sun it does not change dials or settings...
da
Thank you so much!!!! This really helped
Punteggio 0
Omg this makes so much more sense thank you so much.
Punteggio 0
I put my new film in the instax mini 9 but the S is not changing to 10 and it is not taking pictures.
Punteggio 0
Wow! Thanks, it makes TOTAL sense. I was already thinking the camera was broken!
Punteggio 0
Oh wow I was having the same problem with my instax mini 9 and also though it was broken Thanks.
Punteggio 0
Aggiungi la tua risposta
Kelly Giordano sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 27
Ultimi 30 giorni: 112
Tutti i Tempi: 141,969
