Salta al contenuto principale
Step-by-step guides for handheld, stick, canister, robotic, and upright vacuum cleaner repair.
1554 Domande Visualizza tutte
Canister vacuum no suction when brush attached Bosch
1450W 12 amp vacuum
BSG81396UC Premium Prestige Canister Vacuum Cleaner
I was hoping you have advise my vacuum works fine suction etc until
I plug in the hose with peered brush attachment Then there is no suction at all . Hose, filter , and bag are clean and free of clogs
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Well you either have a clog you don't know about or you aren't switching the suction to the hose. Take off where hose starts and see, if you have suction there then you know it's the hose. And if you don't have suction then it's somewhere else. Pretty simple
Punteggio 0
After checking proper suction by removing the hose, inspect the brush for potential obstructions like hair or debris. Remove the brush cover for a closer look. Additionally, run your hand along the hose to check for punctures or leaks, which can significantly reduce suction. Certain models feature adjustable brush heights for various floor types. Confirm that the brush height suits the cleaning surface, as an incorrect setting can impact suction.
Punteggio 0
Aggiungi la tua risposta
DPWCT sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 116
