Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Neither camera working after screen replacement.
After replacing my screen (iPhone 6) neither of my cameras are working (along with the LED flash). When I open the camera app, a black screen appears. I have checked that all ribbon cables are intact (both front and rear camera) and nothing seems to be out of order.
Also, I haven't upgraded to ios 9 for personal reasons. Im running ios 8.4.
Questa è una buona domanda?
Punteggio -1
3 Commenti:
Have you tried a hardware reset? Home and power held down until the phone boots to Apple logo.
da
yes i have tried that
da
Try with new front camera flex. Sometimes that is the fix.
da
Aggiungi un commento
2 Risposte
try back up everything to itune and then put your phone into DFU mode to restore the new software in case that is the software buds. than if you want to stay at iOS 8 or whatever go online download new software that you desired. To use that software ,click on the restore button while holding Shift(win) option(mac) then select the file that you just download
Punteggio 0
Probably only one of the cameras is faulty. The camera app often freezes up when it can't find the first one, making it difficult to switch to the other one. Since the flash isn't working I would start with replacing the back camera first. Download some other camera apps as well. Snapchat for example has the front camera set as default.
Punteggio 0
Aggiungi la tua risposta
alex b sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,328
