How do I wire a tachometer
how do i wire a tachometer on a 1993 jeep grand cherokee
Questa è una buona domanda?
jimmiller1940, as a general answer since we do not know which tach you have, most aftermarket tachometers only have 3 or 4 wires that need to be connected. Usually a green wire for the tach, red for power, black for ground, and white or yellow for the back light. The power wire that gets connected to a 12 volt ignition source, the tach signal wire that connects to the coil or the designated signal wire in your cars wiring diagram.
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 950
1 Commento
what make and model is your Tach? Post some images of the connectors with your question. Use this guide Aggiungere immagini ad una domanda for that
da oldturkey03
