Salta al contenuto principale
Conosciuta come ''PS2'', è una console per videogiochi di sesta generazione rilasciata per la prima volta da Sony in Giappone nel marzo 2000. Negli Stati Uniti è stata introdotta nel 2000 con il modello SCPH-30000. La riparazione di questo dispositivo richiede solo strumenti comuni, ma può essere complicata.
199 Domande Visualizza tutte
Can somebody explain to me how I could possibly repair my playstation
Could somebody please tell me how I can repair my PS2. It is the "fat" model. Not the slim line version. Machine starts up fine, but fails to read discs properly, for example: I will open a game on it and it will play the game for 5-10 minutes where it will then suffer a picture break up or freeze causing the entire game to come an unhappy halt. Also the disc tray will only open when the device is in the horizontal position and not in its normal vertical standing position. How do I go about solving these issues? Any help or advice on these provlems would be greatly appreciated. Thank you in advance.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
I would first recommend trying to follow the PlayStation 2 Optical Disc Drive Lens Cleaning Replacement. If this is unsuccessful, the laser may need to be replaced and then you may want to follow the PlayStation 2 Optical Disc Drive Laser Assembly Replacement .
If cleaning the laser resolves your issue, I would recommend leaving the PS2 horizontal rather than vertically to minimize any strain on the laser from reading the disc or the gears of the drive. If you have to replace the laser, I would recommend leaving it horizontally as well. This might be ideal for the problems of the disc tray opening, if it has been misaligned due to being positioned vertically.
Immagine PlayStation 2
Guida
Pulizia lente unità ottica PlayStation 2
Difficoltà:
Facile
15 - 40 minutes
Immagine PlayStation 2 Ottica laser dell'unità disco
Guida
Sostituzione dell'ottica laser dell'unità disco su PlayStation 2
Difficoltà:
Moderato
20 minutes
Punteggio 1
Aggiungi la tua risposta
titan1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 92
