Salta al contenuto principale
The iRobot Roomba 560, an automated vacuum cleaner, was released in 2009.
Access to Roomba 560 circuit board.
I have a faulty Roomba 560. afer substitution teting I gather the problem is in the board.
I suspect the problem may be in some capacitor as the problem is intermitent but recurring.
simple screw driver dismantling left me short of the pcb.
Where can I find instructions to access the pcb?
Questa è una buona domanda?
Punteggio 1
2 Commenti
Did you try to find solution from irobot customer care? I think you should not fix roomba by yourself, it's still a high tech machine anyway
da
Oh, try to find answers form other sites like http://irobotroombareviews.com/ I've just catched it last week and it's quite useful
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hi, Here's a link to the service manual. Hope it helps.
http://choisirsonaspirateur.info/wp-cont...
Punteggio 3
2 Commenti:
+ research
da
Thanks, most useful info
da
Risposta Più Utile
I had a similar problem, but had to replace some sensors on the board. Looked all over for a fix. Found an affordable one that worked well. took an hour or so.
http://eesolutions.ca/roomba_repair_kit....
I'd recommend it. Took forever to find the site though.
Punteggio 5
Hi.
Here is quick fix for your roomba.
http://www.abstractpath.com/2008/fixing-...
Cheers
Punteggio 0
Aggiungi la tua risposta
Axel Brinck sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 13,514
