Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Earpiece speaker not working
Hello,
I just changed the digitizer and lcd on my 6S and now the earpiece speaker isn't working. I connected everything exactly the way it came off the old screen and am stumped as to why it isn't working properly. Thoughts?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
When replacing the ear speaker, make sure the gold contact points on the flex cable match with the metal springs of the ear piece speaker. The holes of the flex cable should allign perfectly with the little plastic pins in the screen frame.
Punteggio 0
Do what Jake said, did you wear gloves during the repair, if not you might want to clean those gold connector with some alcohol, any oil will cause those connections to work properly.
Punteggio 0
Aggiungi la tua risposta
jeremiahmitchell87 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 628
