Why when I insert a sim card the tablet said invalid card
I insert more than one sim card and they are all working on other devise but in my tablet said invalid card
Questa è una buona domanda?
Is your tablet locked to a certain carrier? You can unlock your device if its not still under contract then it would be possible to use any sim. the original carrier will unlock for a fee or you can use an unlock service off the internet. Or if your ambitious you can root your device and learn from hack sites how to unlock it yourself . Hope this helps
Can you give some helpful sit for unlocking my tablet
How can I know if it's locked
this is a site ive used in the past with http://www.code-unlock-shop.com/?AdGroup...
Probably it's locked, try another SIM card!
I try alote of sim card
most likely because your tablet is locked to a specific carrier. the only way to get another sim card to work in htis instance is to unlock it. luckily you can call the carrier and as long as you don't owe money then they will give you the unlock code for it
But how can I enter the cod... tab3 do not have phone keys because it's gust for data
not sure if i understand what you are asking. Even if the tablet is just for data often times they still have sim cards. there are a few carriers and devices that do not use sim cards but its still ok. using the imei number you can still unlock it and change carriers. just call the original carrier for the data of the tablet and they will let you know what to do with it and how to unlock it whether it has a sim card or not. I hope that this helps you out. good luck with unlocking it
How can I find my carrier
Hi,
If you still have the original SIM card and the tablet still works using it, look on the SIM card for the carrier's name or logo which is usually printed on the card
But I dont2 have my sim card any more
@Emily Hollenbach
Please verify the model number of the tablet?
If you go to Settings > Mobile Networks > Network operators if the tablet is locked to a carrier you will only see the one operator name, if unlocked there should be more or the tablet may work with them as well.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 6,682
1 Commento
invealid sim card salotion for samsung t217s
da Kamran Khan
