Salta al contenuto principale
Modello A1418 / fine 2012 / Processore Core i5 da 2,7 e 2,9 GHz o Core i7 da 3,1 GHz
No Power - won't turn on
My computer just shut down and won't power back on. Won't do anything. It is like it isn't even plugged in. I have tried a different power cord. I tried holding the power button. I have unplugged everything from the usb ports.
I have opened up the computer - I am wondering where the diagnostic led lights are. I am wondering if it is the power supply board - it does look like some wiring melted - although its not black or burnt...
Immagine
Questa è una buona domanda?
Punteggio 2
2 Commenti
The diagnostic LEDs are to the right of the RAM slots.
da
Could be a bad power supply unit
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
Be sure to discharge the big capacitors and handle it with one hand. I may be mistaken, but that looks like where the transformer bridges from the AC side to DC side. It will have very high voltage there. If that's exposed wire in the pic then it is likely indicating a problem. The end of one wire looks yellowish too, as if it may have been hot. All of your symptoms point to a bad power supply. About 70% of the time I see these it's the Power Supply, so I'd definitely put my money there.
Punteggio 2
The diagnostic lights are to the right of the RAM slots.
Punteggio 2
The diagnostic lights are under the RAM slots. See picture
Immagine
Punteggio 1
Aggiungi la tua risposta
Lesli KeepSimple sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 17
Tutti i Tempi: 1,842
