Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone 6 Bent housing no signal/service
iPhone 6 housing bent and motherboard bent towards the bottom of the phone and motherboard, everything works except that it will not get any signal/ cell service. It works on wifi, but on the top where it usually says the carrier it keeps saying searching, even after I pull the SIM card out it keeps saying searching. No bents anywhere near the SIM card reader. Tried a different sim tray, network reset, opened the phone and checked all the connectors and components. I haven't done a restore on the phone. I believe it mind be hardware related because it happened when the phone got badly bent. Any suggestions on things to try or how I can fix the problem. Thank you
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta Più Utile
Reflow the entire cellular section, reball the cellular chips if necessary.
Punteggio 2
What does reflow and reball mean?
Punteggio 1
1 Commento:
Reballing is a method of soldering which requires balls to be placed underneath the chip. The process requires a de-solder and a fully equipped solder station. You have to desolder the cellular chip with a de-solder station and resolder it. Trust me it's a nightmare. You're gonna want to take it to a specialist or get a new phone.
da
Aggiungi la tua risposta
Dewells sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,963
