Salta al contenuto principale
Digital Pocket Memo with slide switch operation.
Why is my speaker making a crackling noise?
When I try to replay my recordings I can barely hear my own voice because of the loud crackling. This malfunction started yesterday after I accidently dropped the DPM to the floor.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Vermutlich Anschluss am Mikrofon abgerissen
da
Aggiungi un commento
1 Risposta
The most likely cause of your problem is that the speaker is blown and needs to be replaced. Another reason could be that one of the solder connections came loose or undone. You should check on that before purchasing a new speaker when there is only a little tin-solder needed. More possible causes for your problem may be listed on the Troubleshooting Page.
If you need help on disassembling the device and checking the solder connections please refer to the provided guide for replacing the speaker.
Punteggio 0
Aggiungi la tua risposta
Ecodesign TU Wien sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 50
Tutti i Tempi: 1,512
