Salta al contenuto principale
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
How to open mini mac a1103
how to open mini mac a1103 and step by step on changing power supply.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The Mac Mini (PowerPC) does not have an internal power supply. The power supply is integrated into the power cable that plugs into the Mac Mini. If you need to change the port that the power cable plugs into, then you will probably have to change the logic board because the plug is soldered to the logic board. You can find the step-by-step repair guides here.
Punteggio 2
1 Commento:
Aggiungi la tua risposta
David sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 8,667
