USB port not working
I tried all the software options to fix my USB ports and so far no success.
when I purchased my mac last year I could make the usb recognize the pendrive when I tilt it to a certain angle but when I release the pendrive off of my hand the mac stops recognizing it.
First, I thought it was an easy fix, I opened the mac to check for any loose components and while I was investigating the board I saw the device in this link below
http://forums.macrumors.com/threads/i-de...
and from this youtube
https://www.youtube.com/watch?v=YvV0hCN4...
at 2:19
I removed the resistor and put it back the result was not good now my mac wouldn't recognize any device no matter how hard I try tilting and changing the angle of the USB connector.
My question is how can i get the resistor or what are the specs of that component.
My USB do have power so I don't think it's the fuse.
Thanks.
Questa è una buona domanda?
6 Commenti
First off that's not a 13" model give me your serial number of the mac so I can tell you component . Are you using hot air or soldering iron tip.
da John
First, thanks for the fast reply.
The serial number is C1MH7JSDDV13
thanks.
da Hamid
Bro, that picture is not a 13" model there is no fan connector opposite side of the usb's , is this the picture of yours or another, that is a 15" model I recognize that large bga
da John
The part that fell off i'm preety sure is a choke coil. I am not sure of the measurement I still think that's a 15" board.
da John
sorry for the confusion the links above are not of my macbook.
I took a picture of my mac and here is the link
https://drive.google.com/file/d/0B0tKh5r...
my mac is 13" and it's late 2011
i damaged the right component inside the red square. I believe the left component is the same.
da Hamid
Mostra 1 altro commento
