Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Domande Visualizza tutte
Domanda Chiusa
MacBook 466 maxium ram
1. what's macbook 466 maximum ram?
apple said that it is 4gb (2gb each). any possibility to install it up to 8gb ?
2. is it possible IF i found higher pc-ram and install it to my macbook?
3. is it possible to modify macbook 466's logic board so i can add a graphic card?
thanks for your attention
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
5 Risposte
Risposta Più Utile
The maximum is actually 6GB (according to Mactracker), you can install a 4GB chip and a 2GB chip. And you cannot change the graphics card.
Immagine PC3-8500 2 GB RAM Chip
Prodotto
$14.99
Immagine PC3-8500 4 GB RAM Chip
Prodotto
$29.99
Punteggio 1
well, if mac has 2 slots available for ram, i can make it 8 gb with 4gb each rite ?
anyway, thanks for your answer :)
Punteggio 0
2 Commenti:
You can Add 8GB of RAM if you please, but your system is only going to recognize and utilize 6GB MAX.
da
Check out the Macrumors.com forums, as well. There are multiple threads on this very topic.
Many people have reported serious instability when using over 4GB in the A1278. Additionally, the system will not boot with more than 6GB.
Punteggio 0
then,
after i ready your answer, i decided to upgrade the ram into 4gb. should i devide it into 2x 2gb or 1x 4gb?
Punteggio 0
1 Commento:
I would use two 2GB
da
can i use A 4GB and a 2GB? cause you said it doesn't run on a 8gb ram right/
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,006
