My computer freezes on the POST screen
I was working at my desk and my laptop froze, so I had to hard reset it...but now it won't get past the POST screen and I can't even reach the BIOS. Any suggestions?
Questa è una buona domanda?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 177
Hi,
Are there any lights on? If so which ones?If they are flashing is there a sequence to the flashes? there may also be beep codes. Here is a list for your PC
http://blog.parts-people.com/2014/06/30/...
da jayeff
No beeps or flashing lights. Power light comes on and stays solid, keyboard is backlit. No response from any inputs on POST screen -F2 or otherwise.
da tanho63
Hi,
Have you tried turning off the laptop, unplugging it from the power, taking out the battery, and holding down the power button for about 30 seconds to discharge any built up static. Re-install the battery and try to start.
da jayeff
Just tried, no dice. I read somewhere that you can reset the BIOS by taking out the coin cell battery, so I did that while I had my tools out...didn't change anything either.
da tanho63
Hi,
Read online about people having the same problem as you. Ended up they had to get a new systemboard installed. Hopefully you are still in the warranty period with your laptop so Dell will replace it. Good luck.
da jayeff
Mostra 1 altro commento
