Salta al contenuto principale
La 700R4 TH (turbo-hydramatic) venne sviluppata per l'uso dopo il 1982 di auto e autocarri GMC e Chevrolet.
37 Domande Visualizza tutte
Domanda Chiusa
Why do I not have reverse when I have other gears?
700R4 or 350 turbo transmission
At first I started losing reverse and O/D gears, so I started driving in 2, 1 gears then I lost them. I was then told it was due to lack of tranny fluid cuz I had a worn out rear seal gasket. So i replaced that and put my drive shaft back in and it looked as if it was not in all the way but I had all my gears back except for reverse. I even put Lucas stop slip fix and I still dont have reverse, am I doing something wrong or what, cuz I don't know?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Check your fluid levels the first gear to go when you dont have fluid is reverse followed by 3rd . If all is good there then youve done damage to the valve body by running it when you had no fluid
Punteggio 1
1 Commento:
Remember when checking fluid to have the motor warmed up and running while checking
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,301
