Salta al contenuto principale
The 1st generation of the Toyota 4Runner that features a removable top .
4 Domande Visualizza tutte
Domanda Chiusa
Why is there a loud pop while going over speed bumps?
Whenever I drive over a speed bump, or go over a pothole the car makes a loud scraping pop. The sound occurs no matter what speed the bump is hit at, but does it marginally better when going over the bump diagonally. What could be causing this problem and does it need to be replaced?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Check the steering linkage under the front of the car between the tires, especially your idler arm. If anything is loose-fitting, try to fix it or replace altogether if it's beyond repair.
Check out this troubleshooting page for more information:
1984-1989 Toyota 4Runner Troubleshooting
Punteggio 0
sound like a coilover need to be replaced
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 748
