Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
Trackpad/Keyboard wont work, minimal water damage to hardware
Alrighty so my trackpad and keyboard wont work, it's sort of crazy how this happened because theres obvious water damage, and nothing ever spilled on my laptop! The apple store confirmed my theory as well. If you familiar with the guts of the newest macbook pro, the logic board is separate from the chip in question. The water damaged circuit board is located center and bottom below the battery. The apple store has a flat rate to fix any hardware issue of 750 dollars which seems absolutely ridiculous. Im using the laptop right now with USB peripherals. I believe now after some research that the circuit board in question is the back side of the track pad. would this make the keyboard not work as well? is the keyboard "hardware" located in the logic board? I really hope not. The apple store guy said that i would need a whole lower case replacement (battery, keyboard, track pad, etc.) but I refuse to believe this. Also would anyone recommend fixing this myself? if I can narrow out what could/should need replacing it will save me a lot of money and frustration. Also I might add that the force touch track pad isn't working properly is a mechanical sense. Its not clicking and feels gummy like a rocks under it or something. Thanks for your time guys!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I've fixed this a couple of times. Hook it up to another Mac in Target Mode. Save your data then reformat the drive. Now do an internet install. See if the problem has resolved itself. I know this sounds simple but it probably took me 40 hours to figure it out. If it works and saves you $750, you know what to do.
UPDATE 11/17/16
Here's MY original question and resolution on this problem:
Trackpad Does not Function Properly
Punteggio 1
2 Commenti:
I went in and did some spot cleaning of corrosion, and honestly with how many times I've brought an apple device back to life with component cleaner It wasn't bad at all. It makes me think humidity was the only think that got to it. I'm not sure how these new trackpads are put together and why exactly the trackpad isnt clicking though. I will give this a try a little later, can't hurt right? Thanks for your time @mayer
da
Did mayer's solution resolve your issue?
da
Did you ever fix it?
Punteggio 0
Aggiungi la tua risposta
Mike Hillenbrand sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,149
