Salta al contenuto principale
Why PowerBook does not start with power cable connceted
Hello,
Few months back my powerbook stopped charging. I replaced the charging cable and it worked for few days. soon, it stopped charging did not boot. I took it to Mac store, they put in a charged battery and connected the power, even then the powerbook would not start. the guy there said it needs the power supply replaced. Can you help?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
You said he replaced the battery and power supply and it still would not start, and then suggested a power supply? Well obviously that won't work. First reset the SMC by removing the battery and AC adapter and holding down the start button for 10 seconds. I would remove the battery and connect the AC adapter and see if you get anything. Any lights? Any sounds?
Punteggio 1
1 Commento:
Good answer +
da
Aggiungi la tua risposta
ssrmsr sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,102
