Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Slow after damaging 2 HDDs
So there's a bit of a mystery.
My Macbook started getting really slow, but a different kind of slow. It eventually loaded the system Yosemite, but then apps took a long time to load.
And even after loadning and having gone to the RAM (8GB) it was still slow.
The IT guy said it was the HDD, so we replaced it .... after some time the same thing started happening. Even right after replacing the HDD I never felt it was as fast as it should be, but I thought it was just my impaired geeky judgement.
Then it got real slow. I could not even post things to Facebook, open new tabs, write e-mails without waiting for the already typed letters to show up.
When I woke it up it would show me the apps, but would take ages to let me use them.
The IT guy said all the rest was fine, at least he said he tested everything.
IMPORTANT: a while ago, the computer would turn off all of a sudden depending on how I grabbed it. And then it started showing a message that the battery might have to be serviced. But it disappeared after the guy fixed the battery bad contact thing.
Now I have purchased a new SSD (HyperX Savage) and we're having all sorts of weird problems again. I won't let us install OSX, it acts just like when I was using Pages or the browser, even in that installation interface (which is greatly lighter than the system itself) it freezes a LOT, the cursor freezes, the typing thing shows typed letters only seconds later.
Does anyone have any clue of what might be going on?
A SATA cable? RAM? Motherboard? Battery issues? Processor?
:( I'm afraid it'll damage my SSD just like it did to the new HDD we had installed. The IT guy tested the HDD and it had all sorts of bad sectors and damaging, A 4 month-old NEW SSD.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Stop! Don't change anything. Your HD SATA cable is bad you'll need to replace it before you do anything else. This is a common problem in this series. IFIXIT even has a special guide just for this problem! Here's the guide to follow: MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement and here is the cable you'll need to get: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable.
Once you replace the cable you'll need to wipe the HD and reformat it to then re-install the OS.
You also likely have a second problem here as your systems fan should have been running hard. It's also possible the CPU went into safe mode as well, both of these symptoms imply the systems thermal control is not working properly (SMC). Download this app to see what is happening: TG Pro. post a screenshot on what it shows you so we can see in your question (edit).
The last thing here is once the system is stable with your HD then and only then should you try upgrading it to a SSD if that is what you want. But make sure the systems firmware is up to date. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers or newer.
Immagine MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Prodotto
$34.99
Punteggio 2
2 Commenti:
Dan, why are you changing the bracket? I have not been doing that.
da
You don't need to, it was just the IFIXIT heading which I copied.
da
Aggiungi la tua risposta
Jackson Bagatoli sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 100
