Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
Home button will not work after replacement
Hello,
I have this stubborn iPhone 5c which I can not get the home button to function. I have replaced both the button and the charging port twice to no avail. Even ios restore. Does anyone have knowledge of this issue?
Questa è una buona domanda?
Punteggio 1
2 Commenti:
did the home button just stopped working by itself? or did this occur after a repair?
da
I was given this phone by a customer. He claims it was never fixed before, I don't see any signs of previous tampering it is just "the home button would only sometimes work."
Well in my experience with it thus far it has never worked.
da
Aggiungi un commento
2 Risposte
check the contacts on the charge port and make sure they are not bent or damaged, also make sure the contacts on your button piece are aligned correctly as well. One issue during a charge port installation can be the port not being aligned properly as well. If all pieces are in correctly and the issue persists it could be a board or software issue. I would try a settings reset as well if all pieces are in there correctly.
Punteggio 0
1 Commento:
Hello,
Thanks for the reply, but I wonder if you read the post and not just the title. I have replaced a thousand charging ports, and this one in particular I have done twice, as well as the home button. I even did the full restore already. I am often able to test a home button on a charging port by simply holding the contacts together, as the screws do absolutely nothing for its function. On this one, however; I can not get function even with the home button and charging port fully installed.
da
The cable with the home button contacts must be aligned exactly right. The cable has two alignment holes that fit over corresponding little nibs when the cable is bent over itself i the proper way. There is also a bit of adhesive on the back of this cable to keep it in place. Then the whole assembly is screwed down. If the contacts are not bent then my guess is that the cable with the contacts is not indexed properly. Regards,
Ed
Punteggio 0
Aggiungi la tua risposta
AWT sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 68
