Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Domanda Chiusa
LCD/Digitizer not working but same assembly will work in another phone
I'm a bit stumped on this... My wife's phone is completely working except for the LCD/Digitizer. I am able to make calls using her cars bluetooth system and phone is visible in iTunes. I'm and very proficient in electronics repair.
I thought it was just the LCD randomly messing up, but I tried using my iPhone 6's front assembly and it didn't work. So, I hooked up the seemingly broken LCD/Digitizer to my phone and it works fine. There is a faint glow coming from the LCD.
I'm left with, somehow my wife's iPhone connector or LCD filters is broken? I don't know where to begin to troubleshoot this. Is there any way for me to get the data off her phone? The home button works, but I have no way of entering the passcode...
Do you think Apple will fix this under warranty?
Thanks for any help!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If the phone is still under warranty and doesn't show signs of abuse, Apple would be a good start.
There is a control chip on the mainboard of the phone that could have gone bad. I lean more towards the simple answer which would be an issue with the connector. Try cleaning the connector on the phone with 99% alcohol (please unplug the battery first) and clean the digi connector at the same time. Once you get the phone back together, hold power and volume together a few times and see if the digi starts working. If that doesn't get it going, I would take it to a reputable repair shop in your area.
Punteggio 1
1 Commento:
I cleaned the connectors and got some white blocks on part of the screen for ~1min but then the same problem still. Probably going to see Apple about repair.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 95
