Salta al contenuto principale
PRAM Battery MacBook Pro Core Duo 15 Inch
Hi
I have had my Mac for 4 years and no problems with the PRAM battery. I am planning to replace the hard drive soon and considering replacing the PRAM battery at the same time.
1: Do you know the life of a PRAM battery i.e. is it a good idea to replace it even though it appears to have no problems (bearing in mind the battery's age)?
2: Your replacement PRAM batteries are marked 'Used' on the web site with a six month warranty. What total life can I expect from one purchased from ifixit?
Kind regards
Richard
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hello Richard, To answer your questions in order
1. I don't know about others but I have always heard the expected life span of a PRAM battery was 5 years.
2. Any used battery is a guess--it might last 5 yrs and it might need to be replaced under warranty. If you are planning to keep the computer more than 6 months I would get a new battery. Less than that your current battery should be fine.
Good luck whatever you decide. Ralph
MacBook Pro 15" Core Duo Model A1150 PRAM Battery Replacement
Punteggio 3
1 Commento:
I generally get 3-4 years out of a pram battery, never had more than that.
Punteggio 0
Aggiungi la tua risposta
Richard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,805
