Can the charging port be replaced?
The port that you put your charging cored into on my Nook Glow Light has a broken pin. Can it be replaced?
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 214
Probably. If you can open your device so that you can see the port and then search on Ebay for micro usb port. Then match up yours to one of the many different styles available. They are all quite cheap. Then its a case of unsoldering yours and soldering on the new one. Thats what I would do. If you don't think you have the equipment to do that scale of soldering then a local phone repair shop should be able to help you out.
da martin nash
