Salta al contenuto principale
Laptop manufactured by Asus, running on Google Chromebook OS. Released June of 2014.
18 Domande Visualizza tutte
Chromebook not powering on.
My Chromebook is not charging even when I plug it in, how can I charge it and turn it on?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
This will suck. Remove sd card. Power off. Hold volume - and power on. Conferm prompts. You should be in. The suck part is this hard start restors the device to stock. All is lost save what was saved to sd. All ways save every thing to sd card. This is less damaging to you in events as this. I hope this helps.
Punteggio 0
If laptop refuses to power on when plugged into power source, your laptop may have a dead battery or the Central Processing Unit may need to be replaced. To address these problems, please refer to our troubleshooting page: Asus Chromebook C300M Troubleshooting.
Punteggio 0
Aggiungi la tua risposta
Jake Van Loon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,984
