Salta al contenuto principale
Model A1138 / 1440x960 screen resolution
85 Domande Visualizza tutte
Loss of wifi range
Hello, I have one of the last PB G4 15' 1,67Ghz, and since a few weeks my laptop WIFI do not work well:
if i am near my Router everythings works fine, but when I am far from the router, I do not see the WIFI anymore.
Any other laptop or Iphone still reach the wifi so it is not linked to the router itself.
I have checked inside the laptop the airport connexion with its antenna an it seems to be OK.
Any suggestion to solve this problem?
Thank you in advance.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
If the connections are good and the router is good that leaves the Airport card. Do you have another you can try in your computer? Ralph
Punteggio 1
You mention "since a few weeks"...did this computer work fine on the router previous to a few weeks ago? If so, can you think of anything that may have happened to the machine around that time, or possibly did you install any network-related software, a VPN, etc.? You could always wipe the system and reload the OS in order to rule out software as being the issue. A friend had a similar problem, and it went away when he wiped the system and went to Snow Leopard. Obviously Snow Leopard will not work on this laptop, but my point is that a fresh install may help. And of course make sure it is fully patched, because very early revisions of any Mac OS tend to have networking and especially wireless glitches.
Punteggio 1
Thank you for these answers.
The whole installation was working since 2 years, and I have made no change at all.
Since the problem has appeared, I'have tried to re install Mac OSX Leopard, and made all the sw update but no change: the wifi range is still poor.
- for me it is not a software issue.
What is strange is that when I am near the router the WIFI works just fine.
I have a professionnal PC, and it still works from everywhere in the house, and it is the same with my iphone in WIFI.
Can it be a problem with the wifi antenna which seems linked to the screen?
Is there a way to put a third party pcmcia WIFI card?
Punteggio 1
1 Commento:
Yes the computer has a pcmia card slot. Ralph
da
Aggiungi la tua risposta
Regis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,016
