Salta al contenuto principale
Prima generazione del Bose SoundLink Mini rilasciata l'1 luglio 2013. Il dispositivo pesa 655 grammi e ha una copertura Bluetooth di 9 metri.
20 Domande Visualizza tutte
The SoundLink Mini isn't playing music!
The speakers show that my device is connected, but I can't hear my music.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
1. Check your devise's bluetooth setting and make sure it is paired to the speaker.
2. Check to make sure the volume is turned up on the speaker.
3. Check to make sure the volume on your device is turned up.
4. Turn off the bluetooth on other surrounding devices that may be paired, or perviously paired with your speaker.
You can also find more troubleshooting tips for this issue on the follow problem pages:
Punteggio 1
1 Commento:
My Bose Soundlink doesn't make any sound. Normally it make sound when I turn it on or pair it with bluetooth. Now nothing and it pair with my phone but no music.
da
my Bose Soundlink works very well, and sounds really great. But it doesnt last than 3 seconds. After I play a song, in 3 seconds I hear a noise and then the sounds gone. But, the sound comes out when I type. If you have any idea, please, tell me. Thanks!
Regards.
Punteggio 0
2 Commenti:
We have the same problem. Mine works well too but it doesn't last 3 seconds. Were you able to fix it?
da
Change the battery
da
Aggiungi la tua risposta
Chris Martinez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 5,806
