Why won't it hold charge?
I fully charged my DigiLand DL1010Q but the batter only lasts for a short amount of time. My device used to hold charge for hours upon hours, and now it only lasts an hour, if that.
Questa è una buona domanda?
If the battery will not hold charge, generally this means the batter is no good. Don't worry though, this is an easy fix. For more information go to the DigiLand DL1010Q Troubleshooting Page!
I have Digiland DL1010Q tablet it won't charged and battery is no good do you have any information that can help fix the battery replacement charging port?
@michaeleason, if you check the device page, there is a guide there for replacing the battery.
DigiLand DL1010Q Battery Replacement - iFixit Repair Guide
Be aware that the battery wires are soldered onto the motherboard, so you will need a soldering iron to do this repair.
I do have one criticism of that guide; their technique for removing the battery is unsafe and can result in the battery catching fire or possibly even exploding. I would suggest flowing some 90% or higher concentration isopropyl (rubbing) alcohol under the battery and let it soak in. Use dental floss to saw through the adhesive under the battery, adding alcohol as needed. Avoid bending the battery if at all possible; you should be able to get it loose with this method without damage.
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 9
Tutti i Tempi: 1,680
3 Commenti
any idea where i can buy a replacement charging port? thanks
da JASMIN LOFTON
I have 2 Digiland DL1010Q one of my tablet is no good because it was a battery and won't charge. And the other tablet is on and off do you have any information that can help fix Digiland DL1010Q to replacement charging port?
da Michael Eason
Digiland DL1010Q tablet is not charged because the battery is no good i want to get it fixed but I don't know how.
da Michael Eason
