Salta al contenuto principale
Ryobi VC120 handheld vacuum repair guide.
4 Domande Visualizza tutte
Why does the vacuum not suck dirt even when powered on?
The vacuum is turned on, and I can hear it trying to suck the dirt up, but the vacuum is having a hard time pulling the dirt into itself.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
Empty and clean the dust bowl, check the filter and make sure there are no obstructions.
Punteggio 2
Its possible u have something blocking the air way. That's why ur motor sounds like its working harder than it should. The item , sock, or wad of dirt MUST be removed or u will burn up ur motor. . . kk
Punteggio 0
Aggiungi la tua risposta
Daniel Saunders sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 189
