Salta al contenuto principale
The Summer Infant 3D Lite is a stroller that features an ultra-lightweight design and easy storage capabilities.
8 Domande Visualizza tutte
Why is my wheel not touching the ground?
Once all the wheels have been placed, they are not balancing properly and one is unable to touch the ground. How can I fix this?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
If the wheels are not all touching the ground, check if the wheels have been properly installed. The front wheels should have arrows on them that both point up, and the back wheels brakes should flip downward. If one of the wheels is not properly installed, just press the silver pin and pull the wheel to remove it, and install it the correct way. Refer to either the front wheel guide or the back wheel guide for more information on replacing the wheels.
Immagine Summer 3D Lite Convenience Stroller Back Wheel
Guida
Summer 3D Lite Convenience Stroller Back Wheel Replacement
Difficoltà:
Facile
10 minutes
Immagine Summer 3D Lite Convenience Stroller Front Wheel
Guida
Summer 3D Lite Convenience Stroller Front Wheel Replacement
Difficoltà:
Facile
2 minutes
Punteggio 0
1 Commento:
Add a link to the guide.
da
I need a new wheels because is very dificult move the strolker. Where can I buy the front wheels?Thanks
Punteggio 0
Aggiungi la tua risposta
Nick Taylor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 37
Tutti i Tempi: 15,642
