Salta al contenuto principale
Summer 3D Lite Convenience Stroller Back Wheel Replacement
  1. Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: passo 1, immagine 1 di 2 Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: passo 1, immagine 2 di 2
    • Set the stroller up so the front wheel is on the ground with the metal push tab up.
  2. Summer 3D Lite Convenience Stroller Back Wheel Replacement: passo 2, immagine 1 di 2 Summer 3D Lite Convenience Stroller Back Wheel Replacement: passo 2, immagine 2 di 2
    • Push the tab in with your finger enough so the plastic can slip out above the tab.
  3. Summer 3D Lite Convenience Stroller Back Wheel Replacement: passo 3, immagine 1 di 1
    • OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
  4. Summer 3D Lite Convenience Stroller Back Wheel Replacement: passo 4, immagine 1 di 1
    • The wheel should slide right off the pole once the tab is pushed out of place. It is now possible to make repairs or replace the wheel completely.
Conclusione
Altre 4 persone hanno completato questa guida.
Nick Taylor
Membro da: 09/28/15
200 Reputazione
1 Guida realizzata
Cal Poly, Team 11-5, Forte Fall 2015 Membro di Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
4 Membri
3 Guide realizzate
2 Commenti
Gd, have a question . Were can u buy spare parts for this type of stroller?
pieterroos - Replica
Can you tell me if you have a rear wheel that will fit a summer 3D go convenience stroller all black?
charles nelms - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 70
Tutti i Tempi: 11,477
