Salta al contenuto principale
Lo Huawei P8 Lite (Modello: ALE-L21), annunciato nell'aprile del 2015, punta sulla bellezza nella semplicità. Le sue fotocamere professionali permettono di scattare foto naturali e nitide anche in ambienti poco luminosi. La modalità beauty abbellisce il viso del proprietario in ogni selfie.
Phone Microphone only works in calls but nothing else
Recently, my phone's microphone stopped working which means it doesn't record sound in videos or audio recordings and also doesn't work in apps. The only exception is phone calls where it does work. Why is this? This has happened a long time ago before and it fixed itself so I left this issue for a while but it's been about a month or so and still nothing has fixed! I need my microphone to work asap because I need to record videos WITH audio for my school project! Need help!
Note: I have tried rebooting my phone
Questa è una buona domanda?
Punteggio 4
1 Commento
My p8 lite does not ring or play sound /alarm / music and it is one week old
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
superelectrolizard ,
it is not software fault. your P8 having secondary mic (use for nice cancellation and voice and record sound with comparing. simply you can find it near the Headphone connector.
Here you can find teardown guide. check the mic contacts connected properly to logic board or replace the mic and see
as you mentioned on your question : not required to test primary mic as it works fine (bottom side mic)
Hope this answer will help you to understand the fault and fix it your self
Cheers!
Punteggio 1
Buddy it seems like a software issue. Try factory reset but don't forget to take backup of your files. Mostly that should make it work!
Punteggio 0
Hi I have Huwaie p8 lite problem in my mobile is mic ni nothing working.during calling I used head phone.pls tell me how to resolve
Punteggio 0
Aggiungi la tua risposta
superelectrolizard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 7,084
