Salta al contenuto principale
This Power Mac G4 has Mirrored Drive Doors.
DIY Power Supply repair?
Is there a way to repair the MDD power supply?
I mean, it might be some specific component that burnt out?
I haven't open the power supply, but am hoping it can be something as simple as a capacitor.
I've been searching and found the next cheapest way (If it works in the long run) is running a external modified ATX PSU based on http://atxg4.com
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
10 Risposte
Soluzione Prescelta
You can try, but the odds of identifying the failed component(s) visually is pretty low. Attempting to trace the energized circuit using a multimeter is extremely dangerous, for obvious reasons.
Fortunately, the PowerMac G4 series use power supplies which are very similar to those commonly found in home built PCs - you may be able to find an appropriate substitute on the shelf of a computer store which caters to the homebrew crowd. As long as the molex connector to the motherboard matches, and the supply wattage is equal to greater than the original supply, you should be fine.
The link you provided seems to point to a resource I personally would take advantage of - the price seems right, especially considering he's done all of the labor and testing!
Punteggio 2
Risposta Più Utile
Check this link:
http://www.applefritter.com/node/23857
Punteggio 3
1 Commento:
That's the one I'd use. +1 Ralph
da
No, it must be replaced.
Punteggio 2
I have successfully used a modified ATX power supply to drive my powermac G4 MDD, the only problem with this is that if you are using an ADC display (Apple Studio Displays), it won't work, since ADC displays use a 25V lead and ATX doesn't provide 25V, but the computer itself will work fine, i tried this on a single 1.25Ghz PMG4 MDD, but it should work on all models
Punteggio 2
I've found a place that now repairs MDD power supplies along with iMac G5 power supplies: http://natramelec.com/g4powersupply/
Punteggio 2
I've done using ATX power supply on G4MDD, thought I made a few mistakes along the way.
http://www.smartfruit.com/node/58
Punteggio 1
I have two MDD's exhibiting the same condition - the power light activates when pressed, but goes dim when released. There's also no chime and no fan activity. The state of the PRAM battery doesn't matter, whether it's used, depleted, new, or even absent. The state of the four RAM slots doesn't matter, whether they're empty, partially full, full, or contain known-bad memory.
I've read that there's a capacitor inside that may be offending. It's 390 uF and 450V at 105 deg. C. It's also 35 mm in diameter and 42 mm in height. I forgot the manufacturer, but recall the name amongst a known set of manufacturers of defective capacitors. Even though there are no visible signs of wear, this person replaced the capacitor and was able to fix his G4.
I'm going to badcaps.net and hope other people can support what this other person experienced. I believed I pull the original story from the Apple Discussions Forum.
Punteggio 1
I also happen to have a 1.25GHz MDD with a failed PSU and i am now using the atx psu of a broken Maxdata desktop PC.
I tried analysing the defective psu but neither rectifier, capacitor or anything else on the primary seems broken, the breaker kicks out as soon as i connect it to my wall outlet. What ponders me though is that the integrated fuse will not blow, though it is rated much less than the breaker.
Be careful when using a new atx power supply! the connector will fit but the pinouts are different and you my end up frying either your logic board or the new power supply. if you don't wanna void the warranty of the new power supply, buy an adapter for 20->24 pin ATX and tinker with that to match the pinout. Use the broken psu for reference as the wire colours will match in most cases. if in doubt, use the pinouts on pinouts.ru or wikipedia as reference. Unlike the ATX standard the MDD logic board does not have a pin for PWR_OK and -5V, so you can leave them unconnected.
Also note that the psu needs to have a really strong 12V line (10A+ recommended) and it can not be any higher than 7cm to fit inside the MDDs case.
Punteggio 1
I have just converted an ATX power supply to work in my G4 MDD Dual 1.2 FW800. I used an APOLLO 300 Watt Micro ATX Power Supply. It's day two and everything is working fine so far including DVD drive and firewire 400. I haven't tested FW800 because I don't have any FW800 devices. I found a post on the internet stating that a 300W power supply should be sufficient without the Apple Display. The internet is full of good information so I went for it. The computer is working, who knows how long it will last? You? You should not do this, you have been warned, there is danger and electricity involved, this list worked for me, you are on your own.
Here is what I did:
  1. Remove the old power supply from the G4 MDD
  2. Cut the wire harness from the old power supply as close to the power supply as possible
  3. Strip 1/2" each from the end of the 24 wires from the old G4 MDD power supply
  4. On the plug from the new ATX power supply, one at a time, cut and strip 1/2" from a wire, matching the color with a wire from the old G4 harness
  5. Twist the matching color wires together, one at a time, solder, and cover with heat shrink. There will be a few black and yellow wires from the MDD that won't have a matching partner on the new harness. Twist two of the same color together from the MDD and use one from the new ATX. You only need to do this 3 or 4 times
  6. The white wire from the MDD (pin 14) is for an Apple Display and isn't used in my configuration. Cover the end with shrink tube and forget about it
  7. Check all of your wires for color matching and heat shrink
  8. There will be a few wires from the new power supply that don't get used, I think there were a couple extra red wires and a grey one, you will figure it out. Shrink wrap the ends and keep with the harness
  9. After checking every set of wires to make sure that the colors match and they are covered in heat shrink, plug in the power supply by itself and make sure it doesn't fry before checking it in your computer
  10. After checking the power supply powered up by itself, plug the power supply into the computer and see if it powers up. If it does, you are a hero. If it doesn't, I told you not to do this in the first place.
Mounting the power supply
I used epoxy to mount four cable tie mounts to the top of the inside of the case, then used cable ties to hang the power supply from the mounts. The PSU fits in just fine and clears the video card nicely. I'm thinking about adding a PCI slot fan for more ventilation but we will see. My G4 MDD has a new lease on life for about $30 USD including the cable ties and mounts.
Also, I picked up a 6" extension Y cable to extend the power going to the hard drive. This proved immensely useful when it came time to stow all the wires behind the DVD drive and up to the power supply.
Punteggio 1
Quite often the fuse will blow, resulting in nothing happening when you try to start the computer. No surprise, right? The puzzle is just what caused it to blow. Obviously, you must replace the fuse, PLUS the thing that failed. I am now working on a PC power supply that failed - one of the large filter capacitors went out by blowing a hole in it's side! This also cooked a power transistor that was right next to it. Since the damage is so visually obvious, and all the parts are accessible, I think I have a real good chance of getting it working. BUT -- I am probably pretty lucky, too. Considering the price of used power mac G4's, you may be better off buying another one for parts. There are sellers on eBay that sell refurbished power supplies for about $140.
Punteggio 0
Aggiungi la tua risposta
riDerz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 94
Tutti i Tempi: 29,168
