Salta al contenuto principale
Modello A1419 / EMC 2806 / Fine 2014 o metà 2015. Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (ID iMac15,1); EMC 2834 fine 2015 / Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (iMac17,1) Tutti con display Retina 5K.
573 Domande Visualizza tutte
Does opening the iMac void the warranty
Does opening the 5K iMac to modify drive capacity, etc. void the warranty?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Since the screen has to be cut into to get it off, I would say yes unless done by an ASP or Apple store. The only thing that it considered user upgradable on this model is the RAM. I could be wrong but I wouldn't bet my warranty on it.
Punteggio 2
It does not. If Apple can prove that when you opened up the case something got broke and you were the cause of it then yes . There is a reason computers have ram slots. To be able to add ram.
Punteggio 0
2 Commenti:
Kevin, this machine does not need to be opened to upgrade the RAM, the RAM slots are on the back.
Sostituzione RAM iMac Intel Retina 5K 27"
da
He asked if he replaced the ram will it void Apple Care. It's still a NO it will not.
da
Aggiungi la tua risposta
sjf sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 424
